ac_coupling:fronius
ac_coupling:fronius [2015-12-03 15:15] – [Setting up the Victron Multi or Quattro] mvader | ac_coupling:fronius [2020-01-19 15:09] – external edit 127.0.0.1 | ||
This document describes how to setup Energy-storage, | This document describes how to setup Energy-storage, | ||
- | The Victron system monitor, the [[http:// | + | The Victron system monitor, the [[https:// |
===== Frequency shifting ===== | ===== Frequency shifting ===== | ||
Line 9: | Line 13: | ||
- | This is a very easy setup. The Fronius Setup MG has been developed in close cooperation with Victron | + | This is a very easy setup. The Fronius Setup Microgrid |
- | * Fronius | + | |
- | Recommended for new systems | + | For new systems the Fronius |
- | When the PV modules need to be grounded, | + | The use of Fronius Galvo inverters |
- | When setting | + | **Compatible UL inverters** (for "US type AC grid") are: |
+ | * Fronius | ||
- | ===== Setting up the Fronius with MG 50/60 ===== | + | For the UL inverters, some more Microgrid Setups are available (e.g. for connection with Neutral conductor or without). Also the UL inverters can be used in 60Hz as well as in 50Hz applications. More information can be found in the user manuals. |
+ | When setting up a system, always update both the Fronius and the Victron devices to their latest firmware versions. For the latest Fronius firmware and information how to update use this link: | ||
+ | [[http:// | ||
+ | ===== Setting up the Fronius with Setup MG50/MG60 ===== | ||
Line 44: | Line 56: | ||
- Note that it is not necessary to change the default settings in the Assistant. \\ {{: | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: | ||
Line 51: | Line 62: | ||
- | More information on adding Assistans is [[assistants: | + | Table for settings for 50Hz and 60Hz frequency |
- | ===== Frequently asked questions ===== | + | | ** State ** | ** 50Hz ** | ** 60Hz ** |. | |
+ | | Start| 51.0 | 60.2|Hz| | ||
- | === Why doesn' | + | More information on adding Assistants is [[assistants: |
+ | ===== Remote system monitoring ===== | ||
+ | The Victron system can be monitored through Victron VRM Portal if a [[https:// | ||
+ | The Fronius PV inverter data can be [[ccgx: | ||
+ | So the VRM portal is the recommended monitoring platform also for AC-coupled installations. | ||
+ | However, also Fronius offers an equivalent monitoring solution. The Fronius portal is called Fronius Solar.web. The PV system data can be transfered to the portal if the inverter is equipped with a Datamanager 1.0 or Datamanager 2.0. | ||
+ | The usage of both portals in parallel is possible. | ||
+ | A video instruction how to set up the Datamanager 2.0 + Solar.web can be found [[https:// | ||
+ | ===== Zero Feed-in ===== | ||
+ | ==== Q1 Why doesn' | ||
+ | See [[: | ||
