ac_coupling:fronius
ac_coupling:fronius [2015-07-28 16:52] – [Fronius / Victron specifics] mvader | ac_coupling:fronius [2020-03-19 15:37] – guy_stewart | ||
- | This document describes how to setup Victron Hub-2 and Off-grid systems with AC-coupled PV (micro grids), using Fronius PV Inverters. For Fronius information on the same subject, see their [[http:// | + | This document describes how to setup Energy-storage, |
- | Integrated system monitoring: use the [[http:// | + | Victron GX Devices, eg [[https:// |
- | ===== Introduction to frequency shifting ===== | + | {{: |
- | To make sure that the Fronius PV inverter works well with Victron inverter/ | ||
- | ===== Fronius / Victron specifics ===== | + | For Fronius |
- | With a Fronius PV inverter | + | A Victron & Fronius training webinar video is available to [[https:// |
- | + | {{youtube> | |
- | * Tolerant voltage and frequency boundaries | + | |
- | * Disable Anti-Islanding detection | + | ===== 1.1 Frequency shifting ===== |
- | * Frequency dependent power reduction according to the graph in the [[http:// | + | |
+ | To make sure that the Fronius PV inverter | ||
+ | * The Fronius PV Inverter must be set to Setup MG, short for Micro-Grid. | ||
+ | * For off-grid systems, load the Multi or Quattro with the PV Inverter support Assistant | ||
+ | And the [[ac_coupling: | ||
+ | ===== 1.2 Fronius / Victron specifics ===== | ||
+ | This is a very easy setup. The Fronius Setup Microgrid | ||
- | * Fronius | + | |
- | Recommended for new systems | + | For new systems the Fronius Symo and Fronius Eco inverters |
- | In case of PV modules that need to be grounded, | + | The use of Fronius Galvo inverters |
- | When setting | + | **Compatible UL inverters** (for "US type AC grid") are: |
+ | * Fronius | ||
- | ===== Setting up the Fronius with MG 50/60 ===== | + | For the UL inverters, some more Microgrid Setups are available (e.g. for connection with Neutral conductor or without). Also the UL inverters can be used in 60Hz as well as in 50Hz applications. More information can be found in the user manuals. |
+ | When setting up a system, always update both the Fronius and the Victron devices to their latest firmware versions. For the latest Fronius firmware and information how to update use this link: | ||
+ | [[http:// | ||
+ | ===== 1.3 Setting up the Fronius with Setup MG50/MG60 ===== | ||
- | - Make sure that the Fronius PV inverter is updated to at least the firmware version mentioned above. See table above. | + | - Make sure that the Fronius PV inverter is updated to at least the firmware version mentioned above. See Inverter list above. |
- After making the inverter operational according to the manual, select the language and after this the country specific setup. | - After making the inverter operational according to the manual, select the language and after this the country specific setup. | ||
- Here choose MG50 or MG60 depending on the system frequency. | - Here choose MG50 or MG60 depending on the system frequency. | ||
- | - Note that it is not necessary to change the default settings in the Assistant. The default settings work together with the default Fronius Micro-grid settings. \\ {{: | + | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: |
- | ===== Frequently asked questions ===== | + | Table for settings for 50Hz and 60Hz frequency |
+ | | ** State ** | ** 50Hz ** | ** 60Hz ** |. | | ||
+ | | Start| 51.0 | 60.2|Hz| | ||
- | === Why doesn' | + | More information on adding Assistants is [[assistants: |
+ | ====== 2. GX Devices & Fronius PV Inverters ====== | ||
+ | By connecting a Fronius PV Inverter and GX device (eg [[https:// | ||
+ | This document describes how to setup the monitoring functions. | ||
+ | ===== 2.1 Requirements ===== | ||
+ | 5. Configure the // | ||
+ | 7. Done! | ||
+ | ^ State ^ Meaning ^ | ||
+ | ====== 3. Frequently Asked Questions ====== | ||
+ | ==== Q1 Why doesn' | ||
+ | See [[: | ||
