ac_coupling:fronius
ac_coupling:fronius [2015-07-17 11:34] – john_r | ac_coupling:fronius [2019-04-14 12:39] – external edit 127.0.0.1 | ||
- | This document describes how to setup Victron Hub-2 and Off-grid systems with AC-coupled PV (micro grids), using Fronius PV Inverters. For Fronius information on the same subject, see their [[http:// | + | This document describes how to setup Energy-storage, |
- | Integrated | + | The Victron |
- | ===== Introduction to frequency shifting ===== | + | {{: |
- | To make sure that the Fronius PV inverter works well with Victron inverter/ | + | |
+ | ===== Frequency shifting ===== | ||
+ | To make sure that the Fronius PV inverter works well with Victron inverter/ | ||
+ | * The Fronius PV Inverter must be set to Setup MG, short for Micro-Grid. | ||
+ | * For off-grid systems, load the Multi or Quattro with the PV Inverter support Assistant | ||
+ | * For on-grid / energy-storage systems, load the Multi or Quattro | ||
+ | And the [[ac_coupling: | ||
- | With a Fronius PV inverter this is a very easy setup. The Fronius Setup MicroGrid (MG) has been developed in close cooperation with Victron | + | This is a very easy setup. The Fronius Setup Microgrid |
- | * Tolerant voltage and frequency boundaries | + | |
- | * Disable Anti-Islanding detection | + | |
- | * Frequency dependent power reduction according to the graph in the [[http:// | + | |
- | * Fronius | + | |
- | Recommended for new systems | + | For new systems the Symo and Eco inverters |
- | In case of PV modules that need to be grounded, | + | The use of Fronius Galvo inverters |
- | When setting up a system, always update both the Fronius and the Victron devices to their latest versions. | + | When setting up a system, always update both the Fronius and the Victron devices to their latest |
+ | [[http:// | ||
- | ===== Setting up the Fronius with MG 50/60 ===== | + | ===== Setting up the Fronius with Setup MG50/MG60 ===== |
- | - Make sure that the Fronius PV inverter is updated to at least the firmware version mentioned above. See table above. | + | - Make sure that the Fronius PV inverter is updated to at least the firmware version mentioned above. See Inverter list above. |
- After making the inverter operational according to the manual, select the language and after this the country specific setup. | - After making the inverter operational according to the manual, select the language and after this the country specific setup. | ||
- Here choose MG50 or MG60 depending on the system frequency. | - Here choose MG50 or MG60 depending on the system frequency. | ||
Line 44: | Line 49: | ||
- | - Note that it is not necessary to change the default settings in the Assistant. The default settings work together with the default Fronius Micro-grid settings. \\ {{: | + | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: |
- | ===== Frequently asked questions ===== | + | Table for settings for 50Hz and 60Hz frequency |
+ | | ** State ** | ** 50Hz ** | ** 60Hz ** |. | | ||
+ | | Start| 51.0 | 60.2|Hz| | ||
- | === Why doesn' | + | More information on adding Assistants is [[assistants: |
+ | ===== Remote system monitoring ===== | ||
+ | The Victron system can be monitored through Victron VRM Portal if a [[https:// | ||
+ | The Fronius PV inverter data can be [[ccgx: | ||
+ | So the VRM portal is the recommended monitoring platform also for AC-coupled installations. | ||
+ | However, also Fronius offers an equivalent monitoring solution. The Fronius portal is called Fronius Solar.web. The PV system data can be transfered to the portal if the inverter is equipped with a Datamanager 1.0 or Datamanager 2.0. | ||
+ | The usage of both portals in parallel is possible. | ||
+ | A video instruction how to set up the Datamanager 2.0 + Solar.web can be found [[https:// | ||
+ | ===== Zero Feed-in ===== | ||
+ | ==== Q1 Why doesn' | ||
+ | See [[: | ||
+ | No, when using a Fronius PV Inverter in a Victron system it is not possible to use the Fronius Smart Meter. | ||
+ | Use any of the [[energy-meters: | ||
