ac_coupling:fronius
ac_coupling:fronius [2015-07-14 09:59] – mvader | ac_coupling:fronius [2023-11-30 07:13] (current) – [Q6 What do I do if my Fronius PV-inverter i guy_stewart | ||
- | This document describes how to setup Victron Hub-2 and Off-grid systems with AC-coupled PV (micro grids), using Fronius PV Inverters. For Fronius information on the same subject, see their [[http:// | + | This document describes how to setup Energy-storage, |
- | Integrated system monitoring: use the [[http:// | + | Victron GX Devices, eg [[https:// |
- | ===== Introduction to frequency shifting ===== | + | {{: |
- | To make sure that the Fronius PV inverter works well with Victron inverter/ | ||
- | ===== Fronius / Victron specifics ===== | + | For Fronius |
- | With a Fronius PV inverter | + | A Victron & Fronius training webinar video is available to [[https:// |
- | + | {{youtube> | |
- | * Tolerant voltage and frequency boundaries. | + | |
- | * Disable Anti-Islanding detection | + | ===== 1.1 Frequency shifting ===== |
- | * Frequency dependent power reduction according to the graph in the [[http:// | + | |
+ | To make sure that the Fronius PV inverter | ||
+ | * The Fronius PV Inverter must be set to Setup MG, short for Micro-Grid. | ||
+ | * For off-grid systems, load the Multi or Quattro with the PV Inverter support Assistant | ||
+ | And the [[ac_coupling: | ||
+ | ===== 1.2 Fronius / Victron specifics ===== | ||
+ | This is a very easy setup. The Fronius Setup Microgrid | ||
- | * Fronius Galvo (1~, 1.5 kW up to 3.1 kW) à use latest FW | + | * Fronius Symo (3~, 3 kW up to 20 kW) -> Software // |
- | * Fronius Symo (3~, 3 kW up to 20 kW) à use latest FW | + | * Fronius |
- | * Fronius | + | |
- | Recommended for new systems | + | For new systems the Fronius Symo and Fronius Eco inverters |
- | To have setup a system, always update both the Fronius | + | The use of Fronius Galvo inverters is not recommended anymore for new applications - the Fronius |
- | ===== Setting up the Fronius with MG 50/60 ===== | + | **Compatible UL inverters** (for "US type AC grid") are: |
+ | When setting up a system, always update both the Fronius and the Victron devices to their latest firmware versions. For the latest Fronius firmware and information how to update use this link: | ||
+ | [[http:// | ||
+ | ===== 1.3 Setting up the Fronius with Setup MG50/MG60 ===== | ||
- | - Make sure that the Fronius PV inverter is updated to at least the above mentioned | + | - Make sure that the Fronius PV inverter is updated to at least the firmware version |
- After making the inverter operational according to the manual, select the language and after this the country specific setup. | - After making the inverter operational according to the manual, select the language and after this the country specific setup. | ||
- Here choose MG50 or MG60 depending on the system frequency. | - Here choose MG50 or MG60 depending on the system frequency. | ||
- | - After connecting the MultiPlus or Quattro with the Battery, you can now connect a computer through the VE.Bus (in combination with the Victron interface MK2USB) | + | - After connecting the MultiPlus or Quattro with the battery, you can now connect a computer through the VE.Bus (in combination with the Victron interface MK2USB) to configure the system with the latest |
- | - Note that it is not necessary to change the default settings in the Assistant. The default settings work together with the default Fronius Micro-grid settings. \\ {{: | + | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: |
- | ===== Frequently asked questions ===== | + | Table with general suggested settings for 50Hz and 60Hz frequency |
+ | | ** State ** | ** 50Hz ** | ** 60Hz ** |. | | ||
+ | | Start| 50.2 | 60.2|Hz| | ||
- | === Why don't the frequency settings in the Multi and the Fronius need to be the same? === | + | Note that although the MG50 for instance has a higher start frequency of 51Hz, there is no real drawback using the proposed value of 50.2Hz. The system will just increase the frequency until the PV inverter regulation kicks in. The value of 50.2Hz will work with a broader range of PV inverters/ |
+ | More information on adding Assistants is [[assistants: | ||
+ | ====== 2. GX Devices & Fronius PV Inverters ====== | ||
+ | By connecting a Fronius PV Inverter and GX device (eg Cerbo GX) together you will be able to: | ||
+ | This document describes how to setup the monitoring functions. | ||
+ | ===== 2.1 Requirements ===== | ||
+ | | Fronius GEN24 | See here for [[https:// | ||
+ | === 2.2.1.4 special procedure for GEN24 model === | ||
+ | In Fronius GEN24 devices with software version 1.14 or higher, the Solar API interface is not activated by default and must be activated if required (e.g. integration of a GX device). | ||
+ | The setting for this can be found on the user interface of the Fronius inverter under " | ||
+ | For GEN24, there is no physical toggle switch required (as there is with other models). | ||
+ | Victron and Fronius have made no tests, nor make any claims about the performance of this integration. | ||
+ | If light flickering issues occur, please contact your Fronius dealer. | ||
+ | 5. Configure the // | ||
+ | 7. Done! | ||
+ | ^ State ^ Meaning ^ | ||
+ | It is possible to make a Zero feed-in system with Victron & Fronius. The Venus device will the control the Fronius output power. See the [[https:// | ||
+ | ====== 3. Frequently Asked Questions ====== | ||
+ | ==== Q1 Why doesn't the frequency settings in the Multi and the Fronius need to be the same? ==== | ||
+ | See [[: | ||
+ | ==== Q6 What do I do if my Fronius PV-inverter is detected as Unknown PV-inverter, | ||
+ | Later Fronius PV-inverters support both the Fronius SolarAPI- as well as the industry standard SunSpec protocol. When SunSpec is not available the GX device cannot properly detect the properties of the PV-inverter unless it is one of a fixed list of known older models. Newer PV-inverters will then show up as Unknown, and you will not be able to configure them as 3-phase. | ||
+ | The solution is to configure SunSpec support on the PV-inverter. | ||
+ | * Log into the Fronius web interface. | ||
+ | * Go to the Modbus tab | ||
+ | * Set Data export via Modbus to tcp. | ||
+ | * set Sunspec Model Type to int + SF | ||
