ac_coupling:fronius
ac_coupling:fronius [2015-07-15 13:20] – [Fronius / Victron specifics] david_fro | ac_coupling:fronius [2019-09-18 08:10] – [Fronius / Victron specifics] schwarzlmueller.martin | ||
- | This document describes how to setup Victron Hub-2 and Off-grid systems with AC-coupled PV (micro grids), using Fronius PV Inverters. For Fronius information on the same subject, see their [[http:// | + | This document describes how to setup Energy-storage, |
- | Integrated | + | The Victron |
- | ===== Introduction to frequency shifting ===== | + | {{: |
- | To make sure that the Fronius PV inverter works well with Victron inverter/ | + | |
+ | ===== Frequency shifting ===== | ||
+ | To make sure that the Fronius PV inverter works well with Victron inverter/ | ||
+ | * The Fronius PV Inverter must be set to Setup MG, short for Micro-Grid. | ||
+ | * For off-grid systems, load the Multi or Quattro with the PV Inverter support Assistant | ||
+ | * For on-grid / energy-storage systems, load the Multi or Quattro | ||
+ | And the [[ac_coupling: | ||
- | With a Fronius PV inverter this is a very easy setup. The Fronius Setup MicroGrid (MG) has been developed in a very close cooperation with Victron | + | This is a very easy setup. The Fronius Setup Microgrid |
- | * Tolerant voltage and frequency boundaries. | + | |
- | * Disable Anti-Islanding detection | + | |
- | * Frequency dependent power reduction according to the graph in the [[http:// | + | |
- | * Fronius | + | |
- | Recommended for new systems | + | For new systems the Fronius Symo and Fronius Eco inverters |
- | In case of PV modules that need to be grounded, | + | The use of Fronius Galvo inverters |
- | To have setup a system, always update both the Fronius | + | **Compatible UL inverters** (for "US type AC grid") are: |
+ | * Fronius | ||
+ | * Fronius Symo 10-15 208-240V (3~, 10 up to 15 kW) -> Software //fro27140.upd// or higher (see FAQ Q5!) | ||
- | ===== Setting up the Fronius with MG 50/60 ===== | + | For the UL inverters, some more Microgrid Setups are available (e.g. for connection with Neutral conductor or without). Also the UL inverters can be used in 60Hz as well as in 50Hz applications. More information can be found in the user manuals. |
+ | When setting up a system, always update both the Fronius and the Victron devices to their latest firmware versions. For the latest Fronius firmware and information how to update use this link: | ||
+ | [[http:// | ||
+ | ===== Setting up the Fronius with Setup MG50/MG60 ===== | ||
- | - Make sure that the Fronius PV inverter is updated to at least the above mentioned | + | - Make sure that the Fronius PV inverter is updated to at least the firmware version |
- After making the inverter operational according to the manual, select the language and after this the country specific setup. | - After making the inverter operational according to the manual, select the language and after this the country specific setup. | ||
- Here choose MG50 or MG60 depending on the system frequency. | - Here choose MG50 or MG60 depending on the system frequency. | ||
Line 41: | Line 53: | ||
===== Setting up the Victron Multi or Quattro ===== | ===== Setting up the Victron Multi or Quattro ===== | ||
- | - After connecting the MultiPlus or Quattro with the Battery, you can now connect a computer through the VE.Bus (in combination with the Victron interface MK2USB) | + | - After connecting the MultiPlus or Quattro with the battery, you can now connect a computer through the VE.Bus (in combination with the Victron interface MK2USB) to configure the system with the latest |
- | - Note that it is not necessary to change the default settings in the Assistant. The default settings work together with the default Fronius Micro-grid settings. \\ {{: | + | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: |
- | ===== Frequently asked questions ===== | + | Table for settings for 50Hz and 60Hz frequency |
+ | | ** State ** | ** 50Hz ** | ** 60Hz ** |. | | ||
+ | | Start| 51.0 | 60.2|Hz| | ||
- | === Why don't the frequency settings in the Multi and the Fronius need to be the same? === | + | More information on adding Assistants is [[assistants: |
+ | ===== Remote system monitoring ===== | ||
+ | The Victron system can be monitored through Victron VRM Portal if a [[https:// | ||
+ | The Fronius PV inverter data can be [[ccgx: | ||
+ | So the VRM portal is the recommended monitoring platform also for AC-coupled installations. | ||
+ | However, also Fronius offers an equivalent monitoring solution. The Fronius portal is called Fronius Solar.web. The PV system data can be transfered to the portal if the inverter is equipped with a Datamanager 1.0 or Datamanager 2.0. | ||
+ | The usage of both portals in parallel is possible. | ||
+ | A video instruction how to set up the Datamanager 2.0 + Solar.web can be found [[https:// | ||
+ | ===== Zero Feed-in ===== | ||
+ | ==== Q1 Why doesn't the frequency settings in the Multi and the Fronius need to be the same? ==== | ||
+ | See [[: | ||
