Hubble HV100
Manufacturer links
Use with the HS19 (650 - 1000 V DC)
Product specifications
Setup guide
Hubble HV100
Manufacturer links
Product page:
Hubble High Voltage 100Ah Stack (1C)
Datasheet:
HV100 datasheet V1.3
Modules per stack:
8 only
(the product allows 3 - 8; 7 or fewer sits below the HS19 range)
Usable voltage range:
717 - 891 V
Capacity:
82 kWh
per stack
Module: 102.4 V nominal (32S LiFePO4), 100 Ah / 10.24 kWh
100 A continuous charge/discharge (1C); up to 8 stacks per string with comms
Setup guide
Contact battery manufacturer for setup instructions.
