Freedomwon LiTE Commercial 300/240 HV+
Manufacturer links
Use with the HS19 (650 - 1000 V DC)
Product specifications
Setup guide
Manufacturer links
Product page:
Freedom Won LiTE Commercial 300/240 HV+
Spec sheet:
LiTE Commercial HV 300/240 spec sheet
Factory-built cabinet, no module count to choose
Usable voltage range:
655 - 817 V
(the HV+ operating window fits the HS19 range as-is)
Capacity:
300 kWh
(240 kWh @ 80% DoD)
Note: the older non-plus HV variant (627 - 780 V) sits partly below the HS19 minimum and is not suitable
Factory-built cabinet, not field-stackable: 300 kWh total (240 kWh @ 80% DoD), 400 Ah
Nominal 736 V, operating 655 - 817 V
400 A continuous/max, 300 kW
Cells: 200 Ah / 3.2 V prismatic LiFePO4; scaling by paralleling complete cabinets
Sibling models: 230/184 HV+ and 400/320 HV+
Older non-plus HV variant: nominal 768 V, operating 627 - 780 V
Setup guide
Contact battery manufacturer for setup instructions.
