Upcoming Event:
Genera 2012
May 23rd - May 25th
Madrid Exhibition Centre, Spain
Exibitor:
Latest News:
Victron sponsor Team FAV
2012 May 2nd
In order to encourage the interest in technique among youngsters, each year the ‘First Lego League’ (FLL) is organised. As Victron Energy supports the aim of fostering technique among youngsters, we are sponsoring 4 children from the “Fruit and Vegetables” (FAV) team from Veendam, The Netherlands. Read full article
Filax 2
Filax 2
Filax: the ultra fast transfer switch
The Filax has been designed to switch sensitive loads, such as computers or modern entertainment equipment from one AC source to another.
The priority source typically is the mains, a generator or shore power. The alternate source typically is an inverter.
With its switching time of less than 20 milliseconds sensitive loads will continue to operate without disruption. The Filax is not intended to supply high power household equipment like washing machines or electric motors.
Documents
More Power
Two AC inputs with integrated transfer switch. The Quattro can be connected to two independent AC sources, for example shore-side power and a generator, or two generators. The Quattro will automatically connect to the active source.
New Quattro. More power.
Two AC outputs
All Quattro- and several Multi inverter/chargers now have two AC outputs. In addition to the standard no-break output, an auxiliary output is available which disconnects the connected load during battery operation. It is, for example, the perfect solution for preventing an electric water heater from discharging your battery.
New Quattro. New Multiplus. Two AC ouputs.
