Try the VRM demo
Total Solar produced
MWh
Watt
Solar yield
BlueSolar PWM
12 / 24 Volt
Solar charge controllers
BlueSolar 12/24-PWM
Three models: 5A, 10A or 20A at 12V or 24V *
  • Low cost PWM controller
  • Internal temperature sensor
  • Three stage battery charging (bulk, absorption, float)
  • Protected against over current
  • Protected against short circuit
  • Protected against reverse polarity connection of the solar panels and/or battery
  • With low voltage load disconnect output
  • Optional remote display (20A model only)
BlueSolar DUO 12/24-20 20A at 12V or 24V *
  • PWM controller
  • Charges two separate batteries. E.g. the starter battery and the service battery of a boat or mobile home
  • Programmable charge current ratio (standard setting: equal current to both batteries)
  • Charge voltage settings for three battery types (Gel, AGM and Flooded)
  • Internal temperature sensor and optional remote temperature sensor
  • Protected against reverse polarity connection of the solar panels and/or battery.
BlueSolar 12/24-10 with timer 10A at 12V or 24V
  • PWM solar lighting controller.
  • Two timers to enable dusk to dawn operation, or limited time after dusk and limited time before dawn operation.
  • Seven segment display to visualize timer settings and analyze fault conditions.
  • Battery status indicator with over discharged warning.
  • Internal temperature sensor.
  • Three stage battery charging (bulk, absorption, float).
  • Protected against over current.
  • Protected against short circuit.
  • Low voltage load disconnect override.
Read entire description Hide info
