Current Event:
Caravan Salon
Aug 27th - Sep 5th
Messe Düsseldorf, Düsseldorf, Germany
Exibitor:
Latest News:
Victron SAIL 2010
2010 Aug 27th
Victron Energy exists 35 years, a milestone that needs to be celebrated! Therefore, Victron SAIL 2010 was organised, in the middle of SAIL 2010 Amsterdam (The Netherlands). Several boats with a waving Victron-flag sailed through the canals of Amsterdam. In the evening there was a spectacular fireworks show. It was a great day! Read full article
VictronView Touch
VictronView Touch
VictronView Touch
The demand for luxury and comfort on boats and vehicles grows every day. Unfortunately, more luxury and comfort means a larger web of wiring and monitoring/control panels. This web creates a confusing and inefficient situation for the user. ED&D Technologies has developed a solution for this universal problem: E-Plex.
Together with ED&D, Victron has developed the ‘VE.Bus to E-Plex protocol Converter’ (VEC). This new product connects Victron equipment to the E-Plex network. The result of a seamless cooperation between the Victron units and E-Plex is simplistic power management of all inverters, Multi’s and Quattro’s. With E-Plex, the user can turn the units on/off and set current limits for the PowerAssist functionality. The power, voltages and values of the AC and DC currents can be read out as well.
Documents
More Power
Two AC inputs with integrated transfer switch. The Quattro can be connected to two independent AC sources, for example shore-side power and a generator, or two generators. The Quattro will automatically connect to the active source.
New Quattro. More power.
Two AC outputs
All Quattro- and several Multi inverter/chargers now have two AC outputs. In addition to the standard no-break output, an auxiliary output is available which disconnects the connected load during battery operation. It is, for example, the perfect solution for preventing an electric water heater from discharging your battery.
New Quattro. New Multiplus. Two AC ouputs.
