Aug 27th - Sep 5th
Messe Düsseldorf, Düsseldorf, Germany
2010 Aug 27th
Victron Energy exists 35 years, a milestone that needs to be celebrated! Therefore, Victron SAIL 2010 was organised, in the middle of SAIL 2010 Amsterdam (The Netherlands). Several boats with a waving Victron-flag sailed through the canals of Amsterdam. In the evening there was a spectacular fireworks show. It was a great day! Read full article
Victron Global RemoteObtaining system information wherever and whenever The Global Remote is a modem which sends alarms, warnings and system status reports to cellular phones via text messages (SMS). It can also log data from Victron Battery Monitors, Multi’s, Quattro’s and Inverters to a website through a GPRS connection. The usage of this website is free of charge. The idea is simple: you can use it to get SMS alarms from a Multi, a Battery System, or both. When monitoring the usage of batteries, it can be extremely helpful to receive under and overvoltage alarms; whenever they occur. For this purpose, the Global Remote is perfect. A prepaid SIM-card (for example) in combination with the Global Remote is adequate for remotely monitoring your system. Advanced usage: Monitoring historic data Taking it one step further, an internet browser and -connection is all you need to view all of the data online. You can simply create an account on the website and add your modem(s). Subsequently you can configure the GPRS connection, which will enable you to monitor the historic data of several basic properties such as system voltages, power levels and status information. All of this data is graphed. These graphs are available in daily, weekly and monthly timeframes. |
Two AC inputs with integrated transfer switch. The Quattro can be connected to two independent AC sources, for example shore-side power and a generator, or two generators. The Quattro will automatically connect to the active source.
All Quattro- and several Multi inverter/chargers now have two AC outputs. In addition to the standard no-break output, an auxiliary output is available which disconnects the connected load during battery operation. It is, for example, the perfect solution for preventing an electric water heater from discharging your battery.
