Try the VRM demo
Total Solar produced
MWh
Watt
Solar yield
BMV-600S series
Battery monitors
The BMV-600S and BMV-602S are high precision battery monitors. The essential function of a battery monitor is to calculate ampere-hours consumed and the state of charge of a battery. Ampere-hours consumed are calculated by integrating the current flowing in or out of the battery.
  • Highest resolution: 10mA (0,01A) with 500A shunt.
  • Lowest current consumption: 1mA.
  • Easiest to wire: the BMV-600 comes with shunt, 10 meter RJ 12 UTP cable and 2 meter battery cable with fuse. No other components needed.
  • Easiest to install: separate front bezel for square or round appearance; ring for rear mounting and screws for front mounting.
The BMV-602S has a second voltage measurement input. This input can for example be used to measure the voltage of a starter battery.
Read entire description Hide info
More information
