Mar 12th - Mar 21st
http://http://www.norboat.no/index.php?page_id=69
Norges Varemesse, Lillestroem, Norway
2010 Mar 11th
To add an extra dimension to the launch of the new wargame 'Battlefield Bad Company 2', Electronic Arts in Belgium organised an unique guerilla action. Read full article
Cyrix 80 / 200 / 400 AThe Cyrix battery combiner is a microprocessor controlled heavy duty relay that automatically connects batteries in parallel when one of them has reached a preset voltage (indicating that the battery is being charged), and disconnects when the voltage decreases below float level (indicating that one or more batteries are being discharged). Cyrix battery combiner are an excellent replacement for diode isolators. The main feature is that there is virtually no voltage loss so that the output voltage of alternators or battery chargers does not need to be increased. |
Two AC inputs with integrated transfer switch. The Quattro can be connected to two independent AC sources, for example shore-side power and a generator, or two generators. The Quattro will automatically connect to the active source.
All Quattro- and several Multi inverter/chargers now have two AC outputs. In addition to the standard no-break output, an auxiliary output is available which disconnects the connected load during battery operation. It is, for example, the perfect solution for preventing an electric water heater from discharging your battery.
