Feb 11th - Feb 13th
http://www.belgianboatshow.be/
Flanders expo, Gent, Belgium
2011 Dec 27th
Capi2 Nederland BV has entered into partnership with Victron Energy BV as part of the integration of Victron products into its Capi2 power distribution system. Read full article
11 |
Two AC inputs with integrated transfer switch. The Quattro can be connected to two independent AC sources, for example shore-side power and a generator, or two generators. The Quattro will automatically connect to the active source.
All Quattro- and several Multi inverter/chargers now have two AC outputs. In addition to the standard no-break output, an auxiliary output is available which disconnects the connected load during battery operation. It is, for example, the perfect solution for preventing an electric water heater from discharging your battery.
